Dyno Run: Getting the most out of it?
I'm taking in my scoot for a dyno run tomorrow morning to see where I'm at before I do some upgrades. My question is how do I learn the most from my run on the dyno? How many runs are necessary just to get a good idea how things are doing? What should I ask the tech...if anything?
I won't be having any tuning done as this is just a preliminary to upgrades being done next week so I'll know how good my results are later.
Anything that I'll be able to tell from the HP/TQ curves?
Is the AFR chart printed out with all runs? I see some with and some without?
Is there any other info I can get off the run that is not typically talked about? Just figured with all that crap hooked to the scoot there would be something I'd be able to learn other than just HP/TQ curves....????
running the stock headpipes. Is yours a California model...with CAT? Hopefully I don't have the same problem.
103" Flat Top Pistons, Stock Cams, HD Stage 1 A/C, SE Mufflers, Stock Headpipes.
Upgrades after baseline dyno: Jackpot dynotuned mufflers, PCV with Autotune
Will let you know on this thread what the results are.
Ask him if you can watch what he does when running your bike and learn from that.
Don't understand exactly what you are looking for. After you get a baseline and decide on your upgrades and do the Dyno again are you going to remove those upgrades if you don't get the results you expect, and then Dyno again? A stage 1 will only take you so far, and your tuner should be able to tell you almost exactly where your numbers will be with no engine work on a new bike.
SG are you running the stock headpipes? My local indy was going to do a baseline dyno run before a PC V install and stated that he couldn't get the sniffers past the Y. I'd be curious to know your results with or without the stock pipes. Good luck on your run tomorrow.
Thanks, Keith
Thanks, Keith
