Dunlop Elite 3's on a 2007?
#81
Went on a 2 day 650 mile ride with the wifey and new E3's. MT90B16 front and MU90B16 rear. They seem to be great tires in both wet and dry conditions. Rode part of the WET Blue Ridge Parkway and on the twisty RT 43 going up hill to the Parkway from Buchanan, VA, and then down the hill on RT 43, they stuck to the road nicely.
Only drawback I can mention is it sounds like the front tire makes a very slight noise (kinda like a truck tire roar) when the bike is vertical but goes away with a slight lean angle (like changing lanes). Not bothersome but noticeable. So far so good!
I also returned from a trip in the Smokies through NC, VA, WV, KY, MD, TN, etc. and quickly gained confidence in these tires in dry and wet conditions on the mountain roads. We were aggressively attacking the twisties, too. After 15k on the rear and considerable tread remaining I'm very impressed.
As good as these tires are for handling and durability that slight whine isn't going to make me change! I'll just turn the stereo up.
#82
I agree iclick, a plugged tire is fine when done correctly. I have done it in the past as well with no problems. I bought a good plug kit as soon as I left the stealership. The pump is on it's way.
I should have replaced the kit I lost before this trip, but didn't and paid the price for it. My own fault. It won't happen again........at least not from a simple puncture.
#83
I showed a few pics of it on the rim too. Around here somewhere.
I'll stay with the 160. I have 40 bucks for a higher load rating and overall better looking tire. But I understand what you're saying. Wide tires are not all that important in the grand scheme of things. But they do look sexy! Get asked about it all the time...
lp
lp
#84
I have a whine or roar from my rear E3, or at least I think it's coming from the tire--maybe the belt, but is hard to diagnose. Started when I replaced the tire in May '08 and hasn't gotten any worse. It diminishes in hard left turns, not so much on right turns. Replaced the front about 5k ago and haven't noticed any noise from it yet.
Didn't always do it. 07 Ultra 14,000 miles.
#85
I also run E 3's on my 06 EGC
I want to bring this post back on top as I also run E 3's on my 06 EGC and am really impressed over the stock Dunlop tires. I run the MU90B16 on the rear and my only concern is the clearance at the rear of the fender. My rear fender is shifted off to the curb side and I can't slip my finger in between the tire and bracket without pushing it in there. The clearance is greater than the thickness my index finger on the other side. Maybe I need to do some tweakin' this winter but all in all I will be replacing the rear soon as I removed a small nail and I already tubed this one from an early puncture... I thought I read somewhere that the E 3's were manufactured in 2 plants. I thought one was outside of the US and one was in the US. Does anyone have impute on this?
Because of my clearance issue think I should stay away from the 160 unless I can tweak the rear fender.
Any ideas?
Any ideas?
#86
I have three E3's here, two on the bike and one new one mounted on my spare rear wheel, and all are made in USA.
#87
#88
So is your concern whether or not the 160's will fit? They apparently will based on testimonials here, but I will stick with the MU90's because they cost $40 less and are designed for the 3.0" stock rims. The 160's need 3.5" rims according to Dunlop specs.
I seen some post about tire problems on this site and thought I read somewhere that the E 3's were produced in 2 different plants. Here is one such site about Dunlop tire issues.
http://www.prweb.com/releases/2009/06/prweb2573444.htm
#89
#90
That is good to hear: I haven't seen anything that specifically spoke of the Elite 3's having this issue. I have read many of your post on the E 3's and it seems you have done your home work. I have found 2 crack like openings on my rear E and I can't determine if they are tire issues or if they are caused by road debris. I have already tubed it so its definitely time for a new one. One of the cracks is on the main surface and the other goes thru a rain grove. I had a couple of friends go down last month in California after loosing a rear tire and I know its a serious issue; weather it is a defect in the tire or a case of the owners not maintaining proper tire pressure I am not sure. What I am sure of is that the performance of the Elite 3's are much better that the stock 402 in MHO...
