'08 RKC Wheels Onto '05 RK Standard...
As the title says; I bought some '08 RKC spoked wheels off a guy for cheap and want to put them on my '05 standard RK that currently has the cast wheels.
I'm getting mixed directions on what to use for the swap.
The '08 wheels are 1" axles versus 3/4" on my '05 correct?
Dealership states new axles, bearings, etc...easy to swap over.
My question is are the lowers needing to be changed and what about offset on the rear pully?
Thanks in advance.
Thanks in advance.
wheels?????
I know that the 08s have 25mm bearings and axle, the 05 have 1" bearings and axle. harley has a bearing kit for $70 each that will allow interchange of wheels from old to new and new to older bikes. check the hd accy catalog on the page before the wheels section and find info as to what you are attempting to do.
