help!..Badlanders load equilizer
BTW - load eq's just add the same load to the bike as the stock bulbs do thus the bike thinks all is ok. If you want to reduce the load on the bike, go with an led relay/flasher and all will be fine. (If you don;t mind a hyper flash on the turn signals, you can just replace bulbs and go from there.)
I didn't think our bikes had flasher relays. From what I was told they have turn signal modules (tsm) or turn signal security modules (tssm).
donjuandr
04-07-2014 02:22 AM
