Signal Light dim
Signal Light dim
Have a problem with my left turn signals. When they are switched on they are considerably dimmer then the right signals, including the left indicator in the fairing.
Before I start tearing apart my wiring harness, wondereing if anyone else has anyone had a similar problem and fornd a fix for it?
Most likely a bad or weak ground.
