PC-V on 2009 HD 103" Stage 1
OK I've been waiting long enough and listening to everyone rave about their PC-V on stock engine configs....I'm sold on the PC-V. I've been patiently waiting for the development of maps for the stage 1 103's and still haven't seen anything. The waiting is killing me!
I'm dying to pull the trigger on a kit with Rush/PC-V from FuelMoto!
Jaime, have you guys got a map for 103's yet???
Anyone else had a map made for this config???
Help, I'm dying to get this motor running/sounding the way it should. I'm tired of sounding like a Honda!
I am using FM's base map and tweaked the Target AFR numbers in the interest of gas mileage. If the going gets hot in summer I can flip the optional switch (any on-off switch will do) and revert to the richer base map to cool things down. This is a very trick package, IMO, that for most of us will eliminate dyno tunes and replacement maps as we upgrade our performance hardware, or if we do. The performance is so good on this TC96 that I may never make any further engine mods.
And don't pass up those Jackpot mufflers! That's the biggest factor in the performance enhancements.
My problem is...last I heard there is no base map for my setup. I hear Fuelmoto base maps are so good there's really no reason to add the auto tune module???
Just trying to see if anyone with a stage 1 103 has gone to PC-V and how they got their base map/tune????????
I too have been waiting for word on the 103". I have an '09 factory 103 (police). I've Emailed FuelMoto several times in the past three weeks with questions regarding the PC-V, but have received no response. I'd like to order and install one ASAP and don't want the auto-tune feature. (I also have an '07 103" with the Zippers closed loop system and don't think it was worth the almost $1K price.)
How about it Jaime ... any answers?
Thanks.
Thanks.
The cruise range is another matter, however, as I'm specifying a much leaner Target AFR than Jamie originally installs in his base maps. If the going gets hot in summer I can flip the switch and revert to the richer base map, so there's no downside to this IMO, and basically a "have your cake and eat it too" proposition. The good thing about the AT is that you don't have to guess at the AFR you're running if you decide to tweak it in this manner. If you want 14.7:1, that's what you specify and that's what you'll get. With the PCIII and PCV with no-AT I was tuning the cruise range by the seat of my pants, watching/listening for detonation, high oil temps, and surging. I never messed with Jamie's map above 40% TP, as I want full performance when it is needed.
If your not a mileage nutcase like me, just install Jamie's base map and don't worry about maximizing mileage. On my '07 leaving zeros in the cruise range amounted to around stoich, which is as lean as you should run it, but I can't speculate on the settings for an '08 or '09. Jamie tells me that compared to my '07 they are set richer at the ECU with ignition advance retarded to bring emissions to EPA specs.
What I like about AT is having the ability to make changes (cams, etc.) without the need for a dyno tune or installing different maps, not to mention the peace of mind knowing your AFR is where you specify it regardless of conditions.
He told me he gets 400 emails a day and can't answer all of them expeditiously. Give them a call and talk to Keith or Jamie.
Hello, we have not yet developed any 103" maps for the 09 bike. Unforunately, it will likely be early spring before we have anything. We must keep our 2009 bike a stock 96" for all of the product testing and development we are involved in at the moment. The Auto Tune module would be the the other option and we would be able to put together a base map for you with the AFR targets to get you started.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
I'm leaving on deployment at the end of March....so I guess it'll have to wait for me to get back...
