DynaMatting n Dynorbing meh Arc mini install
Don't like but splicers, or any of them things.. they are too bulky, and unless you need the ones for quick disconnecting stuff then I'll never use them. Soldering is way better. Besides you couldn't pay me enough to shop at wall-fn-mart. Local auto store is just fine or the downgraded raidoshacks..(not what they used to be..sigh). Or even an audio store for car stereos or the like.
I soldered just about every connection and tightly wrapped each one with electrical tape, I am sure they will be fine. Even put some tubing surrounds on a few of em. A little dielectric light coating too on certain connections.
Still trying to figure out how to tune this amp properly... just don't want to keep taking the fairing off to readjust it. Sounds great now, guess I'll just keep it where it is.
Yeah, I noticed the speaker baffles on Firecap's instructions, they did not show the outer fairing. Good way to go if you didn't buy the Orb package or such.
Pretty close quarters in there with the outer fairing back on, dynaOrbs are sitting right behind the speakers as it is now about an inch or two away. The mat stuff is sound deadening stuff all up and around that area behind the Orbs, guess i could of done with out the mat stuff its pretty heavy.
Lots of vibration of the fairing area with the arc mini amp turned up all the way. No rattle noise or vibration noise tho.... guess I am good. Then again it might of helped with it.
