No, that was the last year for the cam tensioners and shoes. That is why I went to gear drive. A lot of people went to the 07 set up. If I knew then what I know now, I'd used the 07 set up also . I'd still change the cams. INO
The tensioners are "old style" but I think there was a small change in the camplate. Seem to remember somthing like more oil flow. Anyway I am going to upgrade to the 07 and later style. Was going to go with gears but think I changed my mind.
From what I understand, You change the whole cam plate, chains, sprockets and all. The cam bearing diameters are different, I think. So, while you have it apart, go to a little more cam = little more TQ
to go to the 07 and later cam tensioner you have to change the cam support plate,
oil pump.cams,chains, tensioners.
Ther is a fellow forum member who has put the whole kit together and has it for sale
cheaper than you can buy it any where else. His user name on the forum is
Herko Bagger. His real name is John Wadsworth Phone 812 923 9027 His price is about
$750. if you want to see what is needed go to Andrews Conversion Cams.com
