2009 w/ ABS handlebar change?
Old 01-22-2009, 06:49 AM
SGLarry's Avatar
SGLarry
SGLarry is offline
Default 2009 w/ ABS handlebar change?
I'm getting an '09 SG w/ ABS, and the the first thing I'm doing is putting on either the WO Chubby's or Khromewerks +2 sweepers. So, whats the real story.....can this be done on the '09's w/ ABS and what definately needs to changed besides the cluth cable?
Larry
Old 01-22-2009, 07:00 AM
dawg's Avatar
dawg
dawg is offline
Received 3,239 Likes on 1,850 Posts
If you go with the Khromewerks sweepers then nothing beside clutch cable 38649-08 is needed. I don't know about the WO's
Old 01-22-2009, 07:32 AM
artt's Avatar
artt
artt is offline
WO 575s need a 4" over stock clutch cable and nothing else. WO hotline-1-800-3378870. Very helpful
Old 01-22-2009, 08:39 AM
SGLarry's Avatar
SGLarry
SGLarry is offline
Thanks Dawg!
Old 01-22-2009, 08:40 AM
SGLarry's Avatar
SGLarry
SGLarry is offline
Thanks! Then the 2009 throttle wire is long enough to be wired internally?
Old 01-22-2009, 11:50 AM
Peppa1's Avatar
Peppa1
Peppa1 is offline
Nothing but a +3 or +4 clutch cable is necessary. Everything else will work fine. I have changed them out on 2 08's and the 09's aren't any different. I went with the Khrome Werks Sweepers on mine and love them. Great wrist angle.
Old 01-22-2009, 09:34 PM
shekmark's Avatar
shekmark
shekmark is offline
How much will a dealer charge for this bar swap?
Old 01-23-2009, 11:31 AM
hamnhog's Avatar
hamnhog
hamnhog is offline
I was quoted 3.5 hours shop labor plus the clutch cable and ABS brake lines. Internal wiring on the Chubbies is another 2 or so hours. I pick up my 09 ABS Ultra tomorrow with the internally wired WO575's. If you want, I'll give you a rundown of the bill. I ain't gonna be pretty (the bill, that is).
Old 01-23-2009, 03:06 PM
Rem's Avatar
Rem
Rem is offline
just answered related question. wish i was around these people willing to pay dealer's extreme prices... could do it for 1/2 and still get rich. yes, even with abs, you can change, no problem. for the cost of the bar (krome werks sweepers+2 = ~70 bucks) you can get comfortable. cable can be run externally from the fairing. have to loosen and re-align the brake line. just did on my '09 ultra with abs.
rem
Old 01-23-2009, 03:45 PM
ultrarex09's Avatar
ultrarex09
ultrarex09 is offline
Thanks REM
Been waiting for that info as I also have a 09 with abs. I gonna try it which is alot better than $800. Who cares if the cable is outside the fairing.
Thanks
Quick Reply: 2009 w/ ABS handlebar change?
