FLHT Standard Air/Oil Temp gauges
Old 01-20-2009, 12:26 PM
CruzN's Avatar
CruzN
CruzN is offline
Cool FLHT Standard Air/Oil Temp gauges
I have an 09 FLHT standard, I was looking thru the catalog and notice a kit to complete the gauges on an FLHT. It was $99 and comes with both gauges to complete the instrustments.
Has anyone done this ?
Is it plug & play ( the bike is pre-wire for these ? )
comments please ?
Old 01-20-2009, 12:32 PM
AtkRWC's Avatar
AtkRWC
AtkRWC is offline
It is plug and play. Simple install.
Old 04-10-2011, 12:30 PM
the4thgearkid's Avatar
the4thgearkid
the4thgearkid is offline
I looked at the download for the instructions on these... it has wiring diagrams and stuff.
It is truly plug and play or do you have to put that sensor on your frame and splice wires and stuff?
Old 04-10-2011, 02:03 PM
honestbob's Avatar
honestbob
honestbob is offline
No splicing, I put the air temp./ oil (PRESSURE) gauge kit on my 08 FLHT and took less then a six pack. I don't know about an oil Temperature gauge though.
Old 04-10-2011, 03:17 PM
slick hd's Avatar
slick hd
slick hd is offline
Smile Simple
It's really easy to takes longer to get the fairing off then to hook the the oil and temp gauges. slick
Old 04-10-2011, 03:23 PM
Roger M's Avatar
Roger M
Roger M is offline
Just fitted this kit on my 07 FLHT and it is real easy, the kit comes with the oil pressure sender to screw into the engine but I didnt need it as there was already one fiitted and wired in the front of the engine. All I had to do was fit the gauges and plug in the connectors. Now I can sink a few, but I think a six pack is a bit overkill for this job.
Regards, Roger.
Old 04-10-2011, 08:24 PM
Beemervet's Avatar
Beemervet
Beemervet is offline
Don't buy the kit. Buy oil pressure/oil temp instead. The air temp is worthless.
Old 04-10-2011, 08:32 PM
jackhis's Avatar
jackhis
jackhis is offline
What is the advantage of installing an oil temp gauge versus buying an oil dipstick with oil temp gauge?
Old 04-10-2011, 08:35 PM
Beemervet's Avatar
Beemervet
It's in front of you, and the dipsticks have been known to grow legs.
Old 04-11-2011, 05:48 PM
griffy's Avatar
griffy
griffy is offline
The Air Temp Guage is totally worthless as stated above. The oil pressure and oil temp are worthwhile. I have an Ultra which does come with the oil pressure guage and the air temp guage. I replaced the air temp with the oil temp and it was a very easy instal though time consuming. Oil has to be drained, pipe plug removed and sender installed with wireing routed thru fairing. Front fairing has to be removed. And small hands are handy as everything inside the fairing is a tight fit.
Quick Reply: FLHT Standard Air/Oil Temp gauges
