NITROGEN filled tires ?
Nitrogen is used by many 'high end' car dealers as well as in racing applications, as Nitrogen does not expand/contract as much as Air does.
It provides for a more consistent tire pressure, however, if you are out on a road trip and find your tire pressure is low or you have a flat, it may be hard to fill with nitrogen @ Joe Blows tire shop in BFE nowhere...
All things considered, I don't think I'd do it right now.
I found the following on a web search:
How much does Nitrogen cost?
Nitrogen is a DRY light gas that does not burn. The air we breathe is 78% Nitrogen.
The Cost to inflate your tires with Nitrogen is $5 per tire. We will purge the compressed air (oxygen) out of you tire and re-inflate the tire with Dry Nitrogen.
What if I need to add air at some point and don't have access to Nitrogen?
Not a problem. Just top off with air from any compressor. You may lose a little of the benefit of the nitrogen but once you get back home just stop by and we will re-purge your tires for you.
Do I have to pay every time I get Nitrogen added?
No. The only time you have to pay again is when you have a new tire or tube installed.
I have heard that Nitrogen actually helps maintain my tires pressure longer. Is that true?
Yes. A Nitrogen molecule is much bigger than Oxygen. The reason tires loose pressure is because the oxygen molecules actually seep through the rubber and out into the air. Because Nitrogen molecules are bigger they can penetrate the rubber as quickly. On average tire pressures maintain about 3-4 times longer with Nitrogen the regular air.
Where can I find out more about Nitrogen?
For more information about Nitrogen, call or visit Mitchell's Modes
Additional comment from a Harley dealer?
Nitrogen Filled Tires
Smoky Mountain Harley-Davidson & Buell is the only Motorcycle dealer in East Tennessee currently offering Nitrogen filled tires exclusively for motorcycles. Nitrogen is a much safer alternative for tire inflation. If has been used for decades on commerical and military aircraft, NASCAR, Formula 1 and Indy racecars as well as heavy mining and construction vehicles. Nitrogen maintains better tire pressure, keeps tires 20% cooler, improves handling and can reduce tire failures by as much as 80%.
i had air in my tires for about 6 months on my dodge nitro when i bought it back in nov 07. in that 6 months I prolly put air in them 3 times during cold months....
i heard about nitrogen back then and decided to try it. haven't had to add air to my tires since. and one thing I did notice.. the tires are quieter.... hell maybe that's just the little bell that keeps dinging in my head but it seems they are quieter....
