Reasons for better 09 Bagger ride
I've heard a lot of people saying the better ride of the 09 bagger is due to the new frame design. How about the other changes? How much is from the frame and how much from other changes? I was told the 17 inch front wheel is actually the same size as the 16 inch and the difference is in the width of the side wall. The 17 inch has less sidewall so there is less flexing of the tire in turns. They also added trail to the front end to make the ride feel more responsive. Then there is the tread design of the new tires. I'm sure the stiffer frame is part of the reason, but how much is the result of the other changes?
I think part of it IS the lower profile tires (less sidewall flex). The tires, so far as I can tell, are vast improvement over the older Dunlops. Dunno how they will wear, but I sure like how they ride.
Typically a wider tire doesn't translate into better handling, so I wonder about that.
Beary
Why 09?
The reasons I spent the bucks to go from an 07 SG to an 09 Ultra were many: however, the first two are the most important ones, new frame design that among other improvements eliminated the high speed engine wobble when cornering and the next was Brembo 4-piston fixed caliper brakes with ABS. Those two things were HUGE for me. The other things that helped my decision were: 6 gallon gas tank, (for me, I wanted lowers, even though not an 09 thing), the idle temperature management system, which shuts off spark and fuel to the rear cylinder when at idle, a fly-by-wire throttle is now standard, 1 degree of lean angle was added on each side, some have stated info on the tires, but added to that is the new 28 spoke cast aluminum wheels are nice.
Coming back from Sturgis last summer and taking sweepers on the mountain passes on the 07 SG and feeling that engine wobble was really enough for me!! This new bike design holds its line and completes turns like it is on rails. Very impressive improvements.
Garemlin
09-19-2008 01:37 PM
