Only got a short ride in, I liked it, but will order a 15" as I could use it a little higher, also I removed it after about 20 miles as it did not fit well at all, Called Cee Baily and found out from them that my 09 SERG outer fairing is differant than the stock bikes, thats why it fit like chit, They are taking the shield back . They are working on a 09SERG sheild and I should have it next week and it will fit the 09 SERG useing the SERG gasket. The currunt shields are made for the Standard RGs 04 and up. So if you have a 09 SERG phone in your order and tell them its for a 09 SERG and they will fix you up. Very good company to deal with. I have not used the Klock Works sheild, althought it looks kinda the same it is way diffarant as I have seen them. Doc
