How to upgrade passing lamp bulbs to 55 watts??
I've done a search on this but couldn't get the info I needed.
I want to upgrade my '09 Road King's 35-watt passing lamp H3 bulbs to 55-watts bulbs. I have a set of 55-watt H3s, but when I went to fit them I found that H-D's stock H3 bulb has a plastic base that plugs into the bike's wiring harness, making it impossible to swap in a standard H3 bulb. Anyone figure out a way to get around this, or does H-D make 55-watt replacement bulbs that plug in? Did a search on that as well and couldn't find any.
Any info is appreciated.
The stock lamps are GE 881L or NAPA BP881.
Search the web for 881 lamps. Tons of different kinds out there.
http://store.classicgarage.com/wl-ion88150.html
http://store.classicgarage.com/wl-ygh88150.html
If you want a brighter lamp with only a 50w draw, install a GE H7604. You have to do a little wiring mod, but it's no big deal. It's a sealed halogen. They have the standard screw terminals.
I fitted Harley sealed halogens, as my easy way of improving those lamps. Harley do several different styles of replacements. I seem to remember my new ones had flat spade push-on connectors, not screw type, but it was easy to adapt them.
Since you are in Japan just upgrade to a pair of HID 35 watt lights. Unbelievable to say the least. I have a PDF of night shots showing the difference. Like going from a kerosene lamp to daylight. Send me your e-Mail address and I will send you a PDF showing the difference between the two. You can pick them up locally if you like and they would just pop right in once you drilled a hole for the cables. Use my e-Mail address if you wish the PDF & I will reply. If you do not wish to go that route remember to install a different circuit using a relay and at least a 16 GA. dedicated power wire with fuse onto the battery and ground the passing lamps very will as you do need a return circuit (current flows from ground to the + side of the battery).
