2 amp installation in fairing on 09 Ultra
Thought I'd share this with you guys.
About 6 months ago I bought 2 small footprint 2-channel amps to put in my aftermarket fairing that iv'e never heard of. I never got around to it until today when I installed them in my 09 Ultra fairing. I've got hogtunes speakers in both front and rear locations and the factory headunit.
the amps can be found here..
http://www.robotronics.com/Products/...e-ask.tpl.html
the only other thing you'll need is 2 speaker level to RCA adapters to maintain "proper fading function front to rear" although not required because the amps accept high-level inputs also. RCA is cleaner so I went that route.
bought the adapters from best buy for $20 each.
the amps were $45 ea when I bought them.
couple of fuse holders = $5
2 RCA cables = $10
all told I've got $145 and about an hour to install invested here.
these little amps sound AWESOME!!!!
wiring:
power i obtained from the orange-white wire behind the headlight
ground I went straight to the frame with it where the fairing is bolted to the forks.
front right speaker
grey-red = positive
green-black = negative
front left speaker
beige-orange = positive
green-white = negative
right rear speaker
dark green = positive
lt green-brown = negative
left rear speaker
brown = positive
white-brown = negative
the front speaker wires can be found on the #27 plug on the right side (if you're sitting on the bike right) of the back of the radio.
the rear speaker wires can be found on the #28 plug on the left side of the back of the radio.
i know these are not in comparison to anything like firecaps amps or hogtunes amps or haw wired amps you've guys used but just thought I'd share with you a cheaper alternative that seems to work VERY WELL. I don't know the build quality of these nor how long they'll last but figured it was worth a try. I'll keep you posted on my experiences with the amps...
FRIKING BLEW ME AWAY at the sound improvement!
here are the pics:
2 RCA cables = $10
wiring:
front right speaker
grey-red = positive
front left speaker
right rear speaker
left rear speaker
brown = positive
here are the pics:
UltraNutZ
Electrical/Lighting/Alarm
15
03-12-2013 09:35 AM
