Windshield Questions
I have searched the forum, read all the posts, and still have some questions. I have a 07 Elec Glide Classic, Stock shield. I used this to meter height.
http://www.ceebaileys.com/cycle/height-width.htm
The windshield hits me exactly on the lower half of the nose. I am looking at these windshields
10" Wide
http://cgi.ebay.com/ebaymotors/10-WI...1%7C240%3A1318
and 12" Wide
http://cgi.ebay.com/ebaymotors/12-WI...1%7C240%3A1318
I have a special circumstance. I am 6'1 and wear a 32" length pants (inseam) and they are kinda long. I am basically looking at the line of the top of the windshield on it. I also carry a passenger probably 50% of the time. She is 5'9 roughly. Which one would you choose and why? I am really at a loss on this. Anyone out there tall torso like me and ordered a windshield? Please post any pics of these wide windshields too if you have them. Thanks. For searching purposes later, these are Dakota-shield.
10" Wide
and 12" Wide
May I suggest taking a look at the Clearview recurve windshield.
The way it's designed, the air flow off the windshield goes up and over you. I bought the
9 1/2 inch one so I could see over the windshield. It's like having the full hight stock windsheld on, but being able to see over it. With your build, you may be able to order a taller one and get the same results. Call or e-mail the owner at Clearview, he will help you get the correct size. He was very helpfull for me.
If you like the wider style of shields , check out these guys http://www.customflhtwindshields.net/ very good feedback (mostly) from forum members.
The stock shield on your bike should be a 12" , a Harley 9 1/2" would be good if you like to look over the shield.
I had a clearview shield and it was super quality and I could use rainX on it.
Don't try rainX on the stock shield or most aftermarket ones either.
If you don't mind looking through the shield , the 15" Harley might work for you.
I'm 5'8" with a 32" inseam , so I look under the 12" shield by about 3".
I liked the clearview 8" with recurve , but my wife doesn't like the turbulence , so I run the 12" mostly.
The taller shields make the ride more quiet , but can be a pain in the rain and fog.
On my stock shield I use Novus 1 cleaner and it acts somewhat like rainX but is safe to use.
When I was looking for the right height to "look over" the shield , I just set a couple pieces of pinstripe at 8" and 9" above the fairing and made a note of which I could live with for wind protection and visibility , you will have to make this measurement for you.
Good luck
Mick
Good luck
Mick
I'm very close to you 6' with 32" inseams (or shorter)
I sit up pretty straight too. Sore back if I don't.
I have the Half Moon windshields from http://www.customflhtwindshields.net/
I use the 12" for day trips riding. They make it a lot easier to hear the radio.
I can look over the 12" no problem.
The 14" one I have, I have to look though it.
I have a 10" a 12" and a 14"
But you will need to buy the "Mar-resistant" ones. Shipped they are $80.
http://www.customflhtwindshields.net...indshield2.htm
I had a 11" Flat Top to start with, but I didn't like the looks of it, in that tall of a shield.
It did work great on wind buffering though.
10" Dark Tint:
10" Dark Tint:
I guess I'm a couple inches shorter in the torso than you and use an 8" Half-Moon from customflhtwindshields. Wife is 5 ft. and says she has a lot less wind as passenger with this shield. Easier to hear the radio also. I think I'd stick with customflhtwindshields as the are great people to work with and I've heard some negative stuff on dakota-shield
