campers/coffee drinkers
Been using this http://www.camping-gear-outlet.com/c...gear-9641.html for the past 12 years (was $6.99 back then) over a camp fire.
Here's a different twist that works great for me....cold-brewed coffee. No, this is not drinking your coffee cold, it's making a concentrated extract that you just add to hot water. Makes the best, smoothest coffee you ever had. You make up a batch of the extract ahead of time and can just carry that in a sealed container. Much less acid and great if you have acid reflux or heartburn issues.
http://www.toddycafe.com
Here's a tip - don't start with cold water, put the water in the night before w/o the coffee (put a napkin in the spout). Set it on the edge of the coals over night, next morning get the fire going - add in the coffee - 15 minutes tops.
