Switch cap 101
Old 01-09-2009 | 07:35 PM
Kbore's Avatar
Kbore
Default Switch cap 101
Are there tricks to removing the old switch caps on the hand controls on 02 RK with cruise? I'm fixin to replace the stock housings but the Service Manual did not say how to get the caps off. My bro told me the switch is easy to break but didn't tell me why! WTF?
Old 01-09-2009 | 07:46 PM
skydoc's Avatar
skydoc
The trick is patience
Old 01-09-2009 | 08:51 PM
dawg's Avatar
dawg
Switch cap removal tool as found in the chrome switch cap kits. That's why I saved my tool. The kit says the tool is PN#7226-04 but it comes up as an invalid pn# so I don't know what the scoop is.
Old 01-09-2009 | 08:59 PM
Harleypingman's Avatar
Harleypingman
For the horn-type caps, a very small flat blade screwdriver works well; for the audio type caps, there may be a tool included, otherwise fork-type tines work well. It's been a while, but working from the outside by gently prying the cap off the round pivot, then removing the cap from the cog side gets them off; simply reverse when installing the new ones.
The horn and turn signal caps have springs that are one-way install; just pay attention to how the springs were oriented when removing the caps and put them back the same way.
A small magnetic phillips screwdriver is useful when removing the small screws and reinstalling them to secure the metal brackets inside the housing. And be careful not to pinch wires when reinstalling the switch housings.
Good luck with your project.
Old 01-09-2009 | 11:35 PM
Kbore's Avatar
Kbore
I had never thought to open the package- a fork tool was included- with the instructions...duh. THanks for your replies!
Old 01-10-2009 | 12:46 AM
Comfortably Numb's Avatar
Comfortably Numb
Default ...
On my RKC the tool was used to remove the caps on the Cruise 'set/resume' button on the right side hand control and the Cruise 'on/off' button on the left side hand control. The switch caps are best removed with a small flatblade screwdriver as mentioned earlier in this thread.
In my experience, the switches themselves are virtually indestructible. Just watch you don't pinch the wiring getting them back into the housings.
CN
Old 01-10-2009 | 07:52 AM
rock92's Avatar
rock92
you will need patience, beer, more patience, and it will initiate the growth of gray hair...lol
the above posts do address it well though. just follow the instructions.
Old 01-24-2009 | 01:30 AM
Kbore's Avatar
Kbore
I would not wish changing A RK throttle side (with cruise) on anyone. That was one miserable f**king job.
Joshus41
08-16-2016 03:09 PM
Widow_Maker
09-05-2012 07:34 AM
iHarley
05-06-2010 09:51 AM
rath8985
04-04-2008 09:02 AM
Alien Spyder
04-29-2006 01:45 PM
Quick Reply: Switch cap 101
