SE Clutch Spring
Old 01-09-2009, 04:25 AM
FLHXXHLF's Avatar
FLHXXHLF
FLHXXHLF is offline
Default SE Clutch Spring
Just installed a SE clutch spring. Is it supposed to be that difficult to pull back ? The standard clutch was easy but i could tell i got slippage. I have a modified engine with 100/100 .
Old 01-09-2009, 05:32 AM
timberland's Avatar
timberland
timberland is offline
Location: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
Its not that much difference in lever action with just the diaphram spring adder. I installed that plus Barnett's clutch plates. I installed the Barnett kit that add's a clutch plate to the stack. You will notice that difference in clutch pull.
Old 01-09-2009, 05:55 AM
glide2005's Avatar
glide2005
glide2005 is offline
I was told that all it takes to install the SE clutch spring is a snap ring,is that right?
Old 01-09-2009, 06:06 AM
FLHXXHLF's Avatar
FLHXXHLF
FLHXXHLF is offline
Theres a snap ring that has to be snapped out. The bolts taken out then it falls off. YOu have to take the primary plate off also, the clutch spring wont fit through the dirby hole.
As for the clutch feeling a little stronger ! Bull hocky, its a lot stronger. Takes effort to pull the clutch but it flat out inguages the clutch. You may think your clutch dont slip, if youve had any mods done, i would say its a must. I really felt the difference. Its just harder to pull the clutch back now and I wanted to know if that was normal.
Old 01-09-2009, 06:12 AM
glide2005's Avatar
glide2005
Thanks for the enfo
Old 01-09-2009, 07:13 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
I agree.Harder to pull in than the stock spring.
Also it a good idea to lube the cable and check the routing.
Old 01-09-2009, 07:30 AM
Heathen's Avatar
Heathen
Heathen is offline
I used White Bros. easy pull kit..made a big diff..not as costly as most.
Old 01-09-2009, 07:46 AM
Renegade1's Avatar
Renegade1
Renegade1 is offline
I just installed one also, you are 100% in your description. I guess I got spoiled with the stock clutch pull. When I first bought the bike 1 1/2 yrs ago, I couldn't believe how light the clutch pull was compared to my 97' Sportster, now with the SE spring it is like the Sportster was. Gonna take some getting used to.
Old 01-09-2009, 08:04 AM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
I've been running a SE spring for years. I wouldn't call it difficult to pull in. It is stiffer than stock, but not by leaps and bounds.
Old 01-09-2009, 08:51 AM
ken thompson's Avatar
ken thompson
ken thompson is offline
The Schlong Man
Mine easily requires twice the pull of a stocker.
Quick Reply: SE Clutch Spring
