SE Clutch Spring
What I did was this.................I put the SE clutch spring in, and then I put in the EZ pull clutch ramps on the other side of the tranny. This gives me the best of both worlds..........stronger clutch with the stock lever pull.
Steve
I had the SE clutch as part of my 103 upgrade on my 07. (which had the easy pull ramps and teflon cable lining) and It was still MUCH harder of a pull at the lever. Probably twice as stiff in my opinion. Nothing you cant live with, but it IS quite a bit stiffer pull IMHO.
When I sold the 07 and went to the 09, one thing I really enjoyed is the easy pull on the stock clutch.
I guess how I would put it was that my 07 SE clutch wasn't BAD per se, but my 09 stock one is super easy. First time I rode the 09 and pulled the clutch, it was like "is this thing connected to anything"?
Year of the bike matters. I think it was in 06 that the easier pull ramps were put in, and in 07 or 08 when the teflon lined cable housing was added. Im sure proper lubrication (or lack thereoff) plays a part as well. My 03 bike had been neglected in that department when I got it. Once the cable was lubed properly, it was like night and day difference.
HFS
07-21-2015 10:36 AM
