Trying To Find an Oddball Wire Connector
Old 01-08-2009 | 06:44 PM
jag1886's Avatar
jag1886
Default Trying To Find an Oddball Wire Connector
I am trying to find a quick release, somewhat water tight, wire connector to hook up a couple of gauges in my new fairing, I am also going to add a couple more speakers down the road so I will need a quick connect for that also.
I have included a picture of the connector that came with my fairing and I am trying to find something similar to it, I'm sure this kind of connector has some technical name and I have tried everything I can think of on the internet and can't find anything but trailer connectors.
If any one has seen or knows what type of connector this is I would appreciate hearing from you.
Old 01-08-2009 | 06:57 PM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
Is there no name enscribed anywhere on the connector? You may be better off changing it over to a Deutz or one of the other readily available maufactured connectors.
Old 01-08-2009 | 07:03 PM
jag1886's Avatar
jag1886
This is custom connector for the fairing this one has 2 12 gauge and 1 14 gauge wire. I don't want to replace this connector I just want to add another wiring harness with a similar connector so I looks OK.
Old 01-08-2009 | 07:16 PM
gs34doc's Avatar
gs34doc
Yea, I assumed that...probably battery connections right? I'm saying if you can't find a mfg. of that particular connector, go with a good brand name watertight like Deutz when you build your additional harness. Electrical stuff can be real tough to find.
Did you try contacting the fairing mfg and ask them whose connector it is?
Old 01-08-2009 | 08:19 PM
bdp's Avatar
bdp
Deutsch = Connectors
Deutz = Engines
My bad if Deutz happens to make connectors
Old 01-08-2009 | 08:22 PM
gs34doc's Avatar
gs34doc
Of course, you are correct. I can't spell fer nuttin!!!
Old 01-08-2009 | 09:00 PM
jag1886's Avatar
jag1886
Good Lord I'm not looking for a Douche connector I'm trying to find a connector that looks like the one in the picture. It needs to take any where from 2-6 14 gauge wires.
Old 01-08-2009 | 09:08 PM
gs34doc's Avatar
gs34doc
Understood....and I still say, if the connector itself is not identifiable. I think your best shot is to contact the fairing mfg. and ask them whose connector it is.
Unfortunately, the electrical industry is probably the toughest of the parts suppliers to get a handle on.
Old 01-09-2009 | 10:11 AM
cms1528's Avatar
cms1528
I buy many eletronic parts from here, I don't think they will have your particular application but most of the staff has many years of experience and may be able to assist you if you shoot them an email with the picture attached. Good luck, hope it works out.
http://www.baynesvilleelectronics.com/
Old 01-09-2009 | 10:34 AM
dirtdobber's Avatar
dirtdobber
I do understand you are wanting the same type plug.
Maybe something they offer will do what you want, they even carry a cover to help with moisture.
http://www.deutschconnector.com/
Jim
Quick Reply: Trying To Find an Oddball Wire Connector
