Speaker pods w/detachable tourpak
My situation has a lot of moving parts so bear with me while I get to my question...
I have an extra set of Hogtunes speakers just sitting around that I would like to use as rear speakers on my 06 Road Glide with the HK stereo. I also have a detachable tourpak that is off the bike about as much as it's on.
The question is, how would I go about wiring/mounting the 2 rear speakers? It seems like it should be as simple as buying a couple of empty rear speaker pods, attach them to the tourpak with the speakers mounted, then putting an inline plug in the speaker wires so that I can disconnect them when I take off the tourpak. But knowing HD, there's probably something I'm unaware of that makes it more complicated than that.
Can I do it the simple way or do I have to buy an OFFICIAL MOFOCO REAR SPEAKER WIRING HARNESS WITH BAR AND SHIELD EMBOSSED CONNECTORS IN CHROME OR BLACK that's just $159.95 not including taxes, freight and HOG discount?
You could go to an '06 Touring parts book and look at the radio wiring diagram. I don't recall if the rear speakers use the Base audio connector that is already on your bike and plugged into the back of the HK radio or it it uses the Ultra connector that plugs into the back of the HK radio for rear passenger controls (volume, PTT, etc.). If the former, simply add the wires you need with the appropriate connectors. If the latter, buy that Ultra Connector plug and the connectors that go in it at the wire ends. You would need four connectors (two for left and right speakers). Then consult a wiring diagram to identify the correct sockets to use in the plug for the +/- for the left and right speakers. Then have the dealer flash your ECM to turn on the rear speakers. You are basically recreating the Ultra radio connector harness, but using only those circuits necesssary to power the rear speakers and not the rear passenger controls, PTT, etc.
IIRC, Hog Tunes uses a different speaker for the rear speaker pods than the front HT speakers.
Good luck with your project.
