how good do harleys heated grips work, I am thinking of getting some and was wondering if there any good, I have a 08 ultra and the throttle cable is on the inside of the handle bars so im limited on what to use.
I have the ironside heated grips. They work very well. I think the settings run from 1 to 6. I keep mine on 2 and only need to turn them up to 4 when wearing my winter gloves in cold weather. I am very happy with them. Installation cost as much as the grips, however.
When I bought my 07 RKC my dealer suggested I not get the HD grips b because of a lot of warrentee probless. They were installing a snowmobile heated grip with no problems. So that's what I have. Get it! It's the best accessory I have ever put on a motorcycle.
I like mine a lot.
Installation wasn't the easiest. I found the instructions lacking.
Here's a tip, when they have you wire into the fusebox the one pin is
a bus of 4 pins and all have to come out together. I tried forcing just one
out and bent it.
Wound up replacing the whole bus.
I,m going to install them myself, it doesn't look to hard
I was told, by the dealership of course, that with the throttle by wire it was a complicated process which required making sure the sensor was properly tuned. I'm not the mechanically inclined type so I had them do it.
I have them and use them. They work very well. I start out at 4 and end up putting them to 2 and they keep my hands nice and warm.They were part of the options already on the bike from the dealer.
