Notices
LEDs? and Why?
Old 01-05-2009, 07:32 PM
Lawdawg's Avatar
Lawdawg
Lawdawg is offline
Default LEDs? and Why?
After doing a search for LEDs, I am more confused then when I started. Why did you install them?What LEDs did you buy and why? I have an Ultra Classic and was thinking about putting them in. I have the turn signal/break light module that flashed when I apply the breaks. Is there a set of LEDs that will work with the module? I like having the rear lights flash when applying the breaks. (Pictures if you got them would be greatly appreciated)
Thanks
Old 01-05-2009, 07:47 PM
FLTR2008TRIKE's Avatar
FLTR2008TRIKE
FLTR2008TRIKE is offline
I dont have the flash mode installed but did put all LEDs on my trike. The reason for spending the extra money to buy them is
1) They last longer then incandesant bulbs
2) Lower voltage needed to run them
3) They are brighter
I installed http://ridetimetechnology.com/index.htm in my Tourpack Brake lights ( 08 and newere come with LED sidelights installed)
My rear brake lights are from http://Kuyrakyn.com
My front turn signals are from http://www.customdynamics.com/motorcycle_led_bulbs.htm
you will need a load equalizer for both front and rear turn signals. Badlands load eqaulizer is a good product with no heat
Just my two cents
Old 01-05-2009, 07:48 PM
Beemervet's Avatar
Beemervet
Beemervet is offline
You must have seen other bikes with LEDs. MUCH more light. I have Kuryaken LED Silver Bullets, LED fender tip light, LED tail light, and LED Shotgunner grab rail delete unit. I've been hit on my bike by a pick up and a couple of bikes. Can't have too much light back there.
Oh yeah, I have one of those flasher things and LED saddlebag spoilers and LED plate light. And single red LEDs in each side of my fairing below the cigar lighter point. (Helps me find it at night).
You'll like them.
Old 01-05-2009, 07:52 PM
FLTR2008TRIKE
PS : You can have a Back-off module installed to operate the LEDs
Old 01-05-2009, 08:05 PM
bigskyhd's Avatar
bigskyhd
bigskyhd is offline
I have the LED's with the brake flashing modules, and I love em. I've had a ton of folks pull up and make a comment about how bright they are, and how they got their attention at the light. They also have an arrow in the tail light that flashes with the turn signals. I've had em for years, and never once had a problem. They're the Kuryakyn model.
Old 01-05-2009, 08:19 PM
AlleyKatt's Avatar
AlleyKatt
AlleyKatt is offline
I changed over to the Kuryakyn Panacea Smoked LED's. The taillight flashes when you engage the brakes and has directional arrows in it also. I added the RideTimeTechnologies led's to my TP. I hooked them up for Tail/Stop/Turn. You can definately see them day or night. Coming from the trucking industry, it didn't take long to figure out that LED's are less hastle as they last longer and are brighter. LED's tend to cut through fog and be seen vs. incadescent. Plus, I think they just look cool, but what do I know. Just my .02
Old 01-05-2009, 08:21 PM
Willy G.'s Avatar
Willy G.
Willy G. is offline
I have the stop/run/turn module from HD it's not LED but works well.
I also have the HD tri-bar stop/run which is LED and like it as well.
plug and play install, except for the Tri-bar harness being to short.
Old 01-05-2009, 08:33 PM
Richpend's Avatar
Richpend
Richpend is offline
Are the module hard to install? For the novice?
Old 01-05-2009, 08:37 PM
papifun's Avatar
papifun
papifun is offline
i intersted in having the brake like flash. what do i need ? i dont want turn signals to operate when brake likes are applied as dual lamp units. same for the brake light , dont want the turn signal on the brake lights. how about a suggestion .. part #... etc.
i looked at J&P and not sure what i need.
Old 01-05-2009, 08:43 PM
BadPiggy's Avatar
BadPiggy
BadPiggy is offline
These pics arent the best. Couldnt figure out how to turn my flash off on the camera. Anyway, the LED's are superbright...I love them!
Here's a brake OFF-brake ON pic comparison.
Quick Reply: LEDs? and Why?
