LEDs? and Why?
i appreciate the info Beercan, i'll look at the BALIGHTS web site. I don't think i'm quite ambitious enough to try to wire up my own, i dont' mind tinkering and wrenching, but for this i'd rather just plug them in
I was ready to pull the trigger on the Custom Dynamics "Dynamic Clusters" which work as running/brake/turn for the rear, but then i read the disclaimer "Dynamic Clusters™ are NOT Dot approved, for off road or show use only", and that sort of turned me off to them. All i need is to get rear ended and the other guys lawyer saying it wasn't his fault because i didn't have DOT approved taillights
Keith at Ride Time Technology has bright LED's but I've seen nothing brighter than Radiantz. Even in direct sunlight, my Radiantz LED's will cross your eyes. Nobody wants to ride behind me anymore, which is fine with me, I don't have to lead anymore.
Edit: Radiantz also has lifetime warranty.
I won't go with Kury again because of those issues and their horrendous customer service.
I changed over to the Kuryakyn Panacea Smoked LED's. The taillight flashes when you engage the brakes and has directional arrows in it also. I added the RideTimeTechnologies led's to my TP. I hooked them up for Tail/Stop/Turn. You can definately see them day or night. Coming from the trucking industry, it didn't take long to figure out that LED's are less hastle as they last longer and are brighter. LED's tend to cut through fog and be seen vs. incadescent. Plus, I think they just look cool, but what do I know. Just my .02
http://www.customdynamics.com/signal..._modulator.htm
Brake Light Signal Module
Note: This module causes the light out indicator to stay illuminated on most BMW motorcycles, and the cruise control not to engage on 2002 and later Harley Davidsons
i dont want to give up cruise control !
i have a 2008 SG.. would the Backoff XP Module be correct one i need. Anyone have it ?
Will the cruise work with this module ?
