Clean jugs!!!!
My 2005 CVO Electraglide had a silver motor and after a couple of years the fins looked really beat up even though the bike was always cleaned up and dried.
I tried all kinda things to bring the cut edges of the fins back, but nothing really worked. I finally tried something that worked great and on a silver motor it's an easy fix to get the cut edges of your fins back to original or at least pretty close.
Buy some scotchpads...I used the red ones and very carefully rub them on the cut edges of the fins. The pads will cut just enough of the metal to bring them back to life. It's pretty painstaking cause if you accidentally rub off the cut eged, it'll take off metal where you didn't intend.
I used gloves too, cause the pads are rough and will eventually cut your fingers up a bit...
There's varying pads depending on the color and cutting power, but this worked really well. A black motor you'd have to be really careful not to rub onto the black finish.
I got the pads at walmart..
If you're talking about just cleaning up stains and things and you're fins are fine, then this may not be the answer for you. Also, with my new flhx after I wash it, I put a little wd-40 on a rag and carefully rub just the cut edges of the fins...this has kept down the discoloration and deoxidation I get from living close to the ocean...
hope it helps...
hope it helps...
customsoftail200
General Topics/Tech Tips
01-11-2007 11:43 PM
