Sticker Removal From Painted Surface
Guys,
I recently purchased a tour pak which has a few bumper stickers placed on it. I've read a few posts of utilizing a hair drier and WD-40 to remove stickers off of forks and metal surfaces. Would this be a safe approach to use on painted surfaces as well? If not, any other suggestions?
Thanks!
Thanks!
A heat gun/hair dryer and some adhesive remover will work best on plastic or fiberglass panels.A heat gun utilized on the inside works the best as is softens the glue rather than the vynel.If youve never used a heat gun on a painted part, stick with the hair dryer.It will take longer but it works.I would not recomend the eraser on any plastic or fiberglass painted part.The heat transfer created causes delamination much faster than on metal.Heres a good adhasive remover most auto supply's carry.
http://www.shop3m.com/62478765092.ht...KU=62466749306
