Caution when buying new wheels. Read
I recently got some chrome 40 spoke wheels for my 99 Electra Glide from American Classic Motors. I got the too good to be true deal on the 40 spoke front and rear wheels for 350 delivered. I spent another 225 at my local HD Stealer dealer to have the wheel bearing packed and the run out clearance set up and the tire rotors and pulley switched off my wagon wheels. I removed and am installing them myself or I'd be even more in the hole!!. GUESS WHAT? They don't fkcuin fit. Know why??? The wheels they say will fit our glides whether it be the 3/4 bearing like mine or the 1 inch bearings are 16 x 3.5 NOT REPEAT NOT 16 x 3. It makes the tire too blown out and rubs the inside of the front fender. I can only imagine the back will be worse. So the bottom line DONT BELIEVE WHAT THEY SAY/WRITE>>> DO YOUR FREAKIN HOMEWORK and learn from my 650.00 mistake cause now I gotta pay to switch and put the old ones back and you just know they are gonna hassle me for a lousy 300 return because I mounted tires on em. I went off there information as posted on Ebay AND I CALLLED A TECH and was told its a go. SO LEARN FROM MY MISTAKE IF YOUR THINKING OF SWAPPING OUT WHEElS. DONT THROW EM ON AND RIDE ALL HAPPY AND HSIT.
If the listing on ebay was misrepresented and they said the wheels would fit and they don't, then you should be able to return them without question. Still sucks though. If they give you a hard time and you paid w/paypal w/a credit card, then you have several options to get your money back.
What brand tire are you using up front? I have a 4" wheel up front with a Metz 130 and it clears, sorta! I have to literally squeeze it in there, but once it clears the bulging part of the fender bracket (at the forks) it clears fine and no trouble what so ever. I was very nervous too, but it did clear. I used soapy water to get it in there and had to wiggle it back and forth to force it between the fender brackets. Once thru, it was ok. Might want to try it. My wheel is wider than yours. I have alot of friends that have 3.5 wheels on and no problems at all. Maybe they are offset? and shouldn't be. The rear should be fine. Take a look with a light to see what exactly is hitting. Hope that helps.
Jerry
Jerry
Just so I am straight, they advertised a 16x3" wheel and shipped you a 16x3.5" wheel? Any chance they just messed up the shipment and will make it right? Have you talked to them yet?
I know they don't have a flawless reputation, but at least give them a chance to make right before you slam them too hard. Don't get me wrong, I'd be pissed to but you need to make them aware of it and see what they are going to do first.
Just my opinion
Zach
Just my opinion
Zach
