Advice on Lighting for Safety
I'd like to make my RG easier seen by cagers. The lights are currently stock with the addition of the HD run/break on the rear. I've read lot's of post so I'm aware there are many choices. What would you guys recommend as being the best bang for the buck for someone on a limited budget. It seems run/break for the tour pack should be near the top of the list. Should all the signal bulbs be replaced? Thanks for your suggestions.
Several ways to help out the back of the bike.
Hyper lites work very well. HD makes the setup for the turn signals to work as brake lights. Depending on year, add the AUX brake/run light to the license plate area. The new luggage rack with spoiler light, a spooiler by itself. Signal dynamics has a lot of options.
As for the front, a headlight modulator works well...I run amber lights in my fog lamps and this helps....
I've fitted a H4 headlight bulb with a slight blue tint and 55w H3's in the passing lamps,also blue tint. Stock is 35w H3.
The law over here are a bit keen when it comes to anyone other than themselves,ambulances and fire engines displaying a blue light,for obvious reasons,but slight tints are O.K and do get noticed.
One of the best way to add visibility, to the front of your bike, is to mount a pair of running lights low and as far apart as you can. This gives a good triangular light pattern with your headlight (headlights on a RG) and the passing lights. You probably don't have room to mount lights on your engine guard, while the lowers are in place.
Tom
Tom
