Notices
K&N Filter don't fit..Whats up????
Old 12-30-2008, 07:11 PM
Jambon1's Avatar
Jambon1
Jambon1 is offline
Default K&N Filter don't fit..Whats up????
Last month I installed Rinehart TD's and SE Stage 1 Air Cleaner (part # 29260-08) Today I purchased a K&N Filter HD-0800 and the holes don't line up. Im guessing this is not the correct filter?? Does anyone know what the correct filter would be for the SE Stage 1 AC?? Thanks in advance.
Old 12-30-2008, 07:25 PM
JayStronghawk's Avatar
JayStronghawk
JayStronghawk is offline
I also have a 2008 FLHT and K&N Told me needed P/N HD-1508 their High Flow that requires no Mods from Stock Pattern..
Old 12-30-2008, 07:33 PM
07JakeelwoodHD's Avatar
07JakeelwoodHD
07JakeelwoodHD is offline
I have a SE AC on my 07 U/C KN filter HD0800 bolt right up no problems
Old 12-30-2008, 07:34 PM
jackinthebox's Avatar
jackinthebox
jackinthebox is offline
I just bought the kn hd 0800 fitler for my dyna. I think that filter replaces the se ac not the stock filter.
Old 12-30-2008, 07:38 PM
dawg's Avatar
dawg
dawg is offline
Received 3,216 Likes on 1,836 Posts
You nailed it. He bought the wrong one, pre 08's used 0800, 08 and later uses 0818
JayStronghawk
I am sure that the HD-0800 was what I had on the 04 Heritage which was a Stage 1 Round style Filter the Stock Filter is oval with a Flat Bottom..
Old 12-30-2008, 07:41 PM
07JakeelwoodHD
The 08 at the end of your part # means the year the part came out or modified HD may have made some changes to the 08 S/E filters I thought I heard they change the throttle body size in 08 this could be the reason it doesnt fit..Also go to KN web site they will tell u what filter will fit your bike
Joe
Foley Fats's Avatar
Foley Fats
Foley Fats is offline
Harley increased the size on the throttle bodies for 2008, so I believe that you can order a K&N HD-0818 to fit it now.
Old 12-30-2008, 07:50 PM
Bertk's Avatar
Bertk
Bertk is offline
The K&N filter element replacement for the 2008 SE A/C Kit is HD-0818.
Old 12-30-2008, 07:59 PM
Jambon1's Avatar
Jambon1
Jambon1 is offline
The Filter is the same shape and size but the holes don't line up. The K&N website states
SCREAMIN' EAGLE TWIN CAM AIR CLEANERS - TAPERED
  • 5-1/2" Diameter Metal Top Plate has centered 5/16" NC Weld Nut to attach cover
  • Top Plate is Three-hole-drilled to fit standard mounting pattern for Twin-Cam air cleaners
  • 6-1/4" Diameter Molded Rubber Base
ApplicationPart #Replaces Screamin' Eagle Part Numbers
29442-99A, 29442-99B, 29442-99C & 29442-99DHD-0800
Quick Reply: K&N Filter don't fit..Whats up????
