Lowering Front fender on roadking
Old 12-31-2008, 04:26 PM
jag1886's Avatar
jag1886
jag1886 is offline
For this project you need a good center punch and a drill with 1/8, 3/16, and17/64 drill bits. You just remove the front fender, center punch the original rivets and step drill the rivets out, the stock brackets fall off and you bolt the new brackets on with the stainless hardware provided in the kit.
The only extra things I did was to paint the new brackets black, I polished the stainless steel hardware so it looked like chrome and replaced the mild steel spacers that came with the kit with a nice set of chrome spacers from the local hardware store.
It both lowers the fender and moves it back so it fits the tire properly.
The whole job takes 1-1 1/2 hrs to do.
Old 01-02-2009, 07:24 PM
motrhd's Avatar
motrhd
motrhd is offline
Default Lowered Fender
I still have the fender mentioned earlier in this thread, if anyone is interested.
Old 01-02-2009, 08:10 PM
skratch's Avatar
skratch
skratch is online now
Received 4,357 Likes on 2,536 Posts
jag-
thanks, looks good. glad to see that you don't have to drill any new holes in the fender. i have seen a couple of kits that require that. drilling out rivets i don't mind, but i don't want to add any new holes if i don't have to.
Old 01-04-2009, 10:55 AM
FYRDOC's Avatar
FYRDOC
FYRDOC is offline
So does anybody else have any pics or thoughts on any of these kits??? I'm leaning towards the Todd Hollins kit because its cheaper than the Aardvark kit and I can't see a big difference between the 2 aside from price. Ideally I'd like one that helps to tilt the fender forward some but I'm thinking that wont happen unless its a weld on kit or you have to drill new holes, neither one of those ideas am I too fond of.
Thanks
Old 01-04-2009, 03:51 PM
gmc's Avatar
gmc
gmc is offline
MOTRHD, sorry I didn't take your fender. It's a great deal with smooth rivets and the nativecustom bracket welded in already. Good luck.
Old 01-04-2009, 04:28 PM
jag1886's Avatar
jag1886
jag1886 is offline
FYRDOC
They aren't tipping the fender forward they are moving it back to make it fit the tire better.
Old 01-04-2009, 10:25 PM
motrhd's Avatar
motrhd
motrhd is offline
They should be lowering the fender and moving it back both. The proper set up is to have the lower line of the fender level front to rear.
Old 01-05-2009, 02:07 AM
cgonzgo's Avatar
cgonzgo
cgonzgo is offline
Mine is from native custom, I got it off e-bay a couple of years ago already done. I like the no rivet look. I added the fender tip light back recently, just think it looks better on my bike. I might have gone with the bitchin brackets though, I don't like the bolt on ones. Which ever way you go, it will look good....
Old 01-05-2009, 10:55 AM
drcarter0734's Avatar
drcarter0734
drcarter0734 is offline
I am planning on lower my fender as well. I was looking at the kit offered by TWR http://www.twrbaggersplus.com/front_fender_lowerin.html
Old 01-05-2009, 12:18 PM
cgonzgo's Avatar
cgonzgo
cgonzgo is offline
Pretty sure that is the one in this months AIM. I just don't like the bolt heads, but thats just me....
Quick Reply: Lowering Front fender on roadking
