How the heck...
Old 12-29-2008 | 12:38 PM
mkbrower's Avatar
mkbrower
Default How the heck...
...do you get burned rain gear off the exhaust pipe. I was riding in the rain yesterday and my rain pants melted on the hot exhaust. I'v tried everything I can think of to get it off but have failed. any suggestions would be appreciated!
Mark
Old 12-29-2008 | 12:43 PM
1flhtk4me's Avatar
1flhtk4me
Have you tried acetone or Goof Off?
Old 12-29-2008 | 12:46 PM
Flower Pot's Avatar
Flower Pot
A razer blade works the best on warm pipes.
Old 12-29-2008 | 12:48 PM
hpfatboy's Avatar
hpfatboy
Thumbs up
Relax , warm pipes up a little. Then try rubbing with some NEVR-DULL and some AUTOSOL. You can get these products at your local parts shops.
Old 12-29-2008 | 12:51 PM
HDRider2002's Avatar
HDRider2002
+1 on the warm (not hot) pipes and some Nev-r-Dull, i've used this method many times to get rubber from boots, etc off my pipes.
Old 12-29-2008 | 12:52 PM
Wassup8687's Avatar
Wassup8687
Easy Off Oven Cleaner.
Old 12-29-2008 | 12:53 PM
BlackMarshmallow's Avatar
BlackMarshmallow
Warm it up, clean with 0000 steel wool. If you use oil based cleaning products, I'd think you'd want to wipe the pipes down with 50/50 alcohol/water to remove the oils. I've used the steel wool/heat methods numerous times and it works great.
Good luck
Old 12-29-2008 | 12:56 PM
TexasSG's Avatar
TexasSG
I've tried most, if not all of the above but Easy-off oven cleaner
works the best, no rubbing involved. Tape off (I used painters
masking tape and newspaper) the area you want to clean as I
doubt you want to get the cleaner on anything but the pipes.
Spray it on, leave it sit for a few hours then wipe it off, simple.
Old 12-29-2008 | 01:11 PM
TexasSG's Avatar
TexasSG
Old 12-29-2008 | 01:17 PM
CTRoadKing's Avatar
CTRoadKing
Easy Off Oven Cleaner works best for me...
Quick Reply: How the heck...
