Satellite radio inside fairing
Old 12-26-2008, 02:31 PM
williamfrog's Avatar
williamfrog
williamfrog is offline
Thanks all , I'll try it under fairing on top of radio . Hope it works in Pa.
Old 12-26-2008, 02:49 PM
SteveO's Avatar
SteveO
SteveO is offline
All the Ultra factory XM antennas are mounted inside the fairing as well as the GPS antenna. Both my XM and GPS work just fine inside the fairing.
Old 12-26-2008, 06:17 PM
Rottiman's Avatar
Rottiman
Rottiman is offline
Location: Ontario, Canada home of the TAX YOU TO DEATH LIBERALS
Tucked my antenna on top of dash on my RG down along the painted strip on lower edge of windshield. Out of sight and the reception is great.
Old 12-27-2008, 04:08 PM
bjryman's Avatar
bjryman
bjryman is offline
Default Used Bracket
Just installed my Zumo 550 and used bracket
Old 12-27-2008, 05:46 PM
bagman1's Avatar
bagman1
bagman1 is offline
Mounted mine on the bracket in the fairing, rode thru 8 western states and never once lost a signal on xm except mabe once in a long tunnel in the mtns.
Old 12-27-2008, 06:18 PM
debay's Avatar
debay
debay is offline
Talking
Rock92 I really like your paint job. Load that bike up less stops
Old 12-27-2008, 06:19 PM
RexBuck's Avatar
RexBuck
RexBuck is offline
Boy, I didn't realize that Garmin antenna was such a big, ugly hockey puck.
Old 12-27-2008, 06:51 PM
TJB50's Avatar
TJB50
TJB50 is offline
My 07 I had the dealer install the XM and they installed the antenna on top of the radio. The reception was marginal at best. I just finished installing the factiory XM myself on my new 09 Ultra and located the antenna on the bracket at the top of the fairing inside and I have max reception, 3 bars. I guess if you want it done right due it yourself! I also installed 2 new front speakers, the latest J&M's. I have the back 2 on order. The system sounds great.
Old 12-27-2008, 10:14 PM
TheShrink's Avatar
TheShrink
TheShrink is offline
I put mine on top of my radio, it's magnetic like the rest. Absolutely no reception problems at all - ever. I don't like seeing wires either.
Old 12-28-2008, 07:43 AM
tpb857's Avatar
tpb857
tpb857 is offline
Veteran: Marine Corp
I don't know whereabouts in Pittsburgh you are, but I live near the airport and have XM on an 09 SG. The antenna is under the fairing (I just saw it when installing an ARC mini last week) on a small bracket not far from the bottom of the windshield to the right if you are looking at the front of the bike. As another post above said, it looks as if the bracket was made to mount the antenna. The XM goes out in several places, but only momentarily. Really not a problem.
Quick Reply: Satellite radio inside fairing
