Engine light comes on while accelerating
12-25-2008, 11:38 PM
Engine light comes on when I roll on throttle, happens at about 2500 rpm and up. Anyone have any ideas on what would be causing this?? Seems to come and go. Checked for codes but did not show any. Any help would be much appreciated. Thanks and Merry Christmas To All..
12-26-2008, 06:11 AM
First, check your plug wires. I had one loose and did the samething. Hope that is it for you too.
12-26-2008, 06:17 AM
If intermittent would check close for any wires that might be loose .. Whatever it is evidently is not shutting you down anyway.. Good Luck here..
12-26-2008, 03:12 PM
Quote:
Originally Posted by
jkoch09ultra
What he said! Had the same thing happen.
12-26-2008, 03:13 PM
jkoch09ultra
12-26-2008, 03:15 PM
Obviously, not twisting the throttle far enough... you need to give her a lot more throttle! lol
12-26-2008, 03:59 PM
Found the same on mine too....loose plug wire at the spark plug.
12-26-2008, 06:09 PM
Location: Ontario, Canada home of the TAX YOU TO DEATH LIBERALS
Had a similar problem, discovered loose wire connection @ IAT Sensor. Once repaired problem went away.
Harleyrider1648
04-26-2016 07:34 AM
tripacer1
08-31-2012 08:32 AM
Rubber Slinger
04-02-2010 09:17 AM
06bob
08-08-2008 11:29 AM
markymark
05-24-2008 09:25 PM
accelarate ,
accelarating ,
accelerating ,
acceleration ,
alot ,
check ,
davidson ,
davison ,
egine ,
engine ,
give ,
harley ,
king ,
light ,
oil ,
road ,
throttle
