Cam Installation Question???
Old 12-22-2008, 05:32 PM
jag1886's Avatar
jag1886
jag1886 is offline
Default Cam Installation Question???
I was thinking about have one of the local shops here in Boise do the install on a set of cams in my 07 RK, the problem I have is they all quoting 3-4 hrs more labor than the job is suppose to take, I guess I'm suppose to pay for smoke, pee and lunch breaks while they are doing it.
This looks like a very start forward job and the only part I don't understand is the turning the back tire while you are tightening something to do with the oil pump.
No one has ever explained this procedure. Could anyone explain how to do this part of the install? I know it's very important so everything seals up properly.
Any extra inside hands on information would be appreciated.
I do have a Harley service manual and a parts manual also.
Can anyone also tell me which specialty tools are needed?
I know there is a lock for removing the drive gears and alignment pins you use on the oil pump.
I will not be ripped off by the local indys just because they obviously don't know what they are doing. The few extra tools cost way less than the $500 they want to do the job.
Old 12-22-2008, 05:44 PM
HB's Avatar
HB
HB is offline
www.harleyhog.co.uk
Try looking at this. It may help.
Old 12-22-2008, 05:58 PM
scotty3's Avatar
scotty3
scotty3 is offline
https://www.hdforums.com.au/Default....ics&forumid=24
Cam Swap Day 1 to 5 was done slowly and is for all the 07 up bikes and worth a read
Old 12-22-2008, 06:25 PM
stro1965's Avatar
stro1965
stro1965 is offline
Cam swap only should be 4 hours if I remember correctly. What are they saying?
Old 12-22-2008, 06:40 PM
molsen's Avatar
molsen
molsen is offline
You will need inner cam bearing puller, installer, and cam and crank sproket lock up tool. I have a Jims tools. Very easy. On the 96 inch you have to do a couple of roatations of the pump. Sounds harder than what it is. Took my personally 6 hours because I took my time and had a bum knee at the time. Adjusting the pushrod is the most critical part. for setup, Along with alingin the dots on the cam. Hope that helps.
Old 12-22-2008, 06:59 PM
jag1886's Avatar
jag1886
jag1886 is offline
Stro1965
I said to the locals you are quoting 6.5 hours for a 3-4 hr job. There responce was SO!!!!!!
Old 12-22-2008, 07:10 PM
shekmark's Avatar
shekmark
shekmark is offline
How many hours did HD dealer say?
Old 12-22-2008, 07:38 PM
Zimbob's Avatar
Zimbob
Zimbob is offline
You did tell them "SO that's why you won't get the job" didn't you. Arrogant morons. Give corporate a call along with better busness. Name names.
Old 12-22-2008, 07:45 PM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
Call the BBB for what? They gave a quote. If you don't like it, feel free to go somewhere else.
4 hours is about right for a cam swap, but that won't include any tuning.
Old 12-23-2008, 01:34 PM
jag1886's Avatar
jag1886
jag1886 is offline
I did get a quote today from the local Harley dealer, they told me 6 hrs, turns out they are charging the same price for a cam install on all years of bikes, I did however find out that the extra labor is for removing the gas tank and rocker covers.
They are doing it the hard way!! So I asked about the quick change push rods and the guy said that they can do it that way and the labor differance is about what the push rod kit costs. I asked them to give me a written estimate for the job, including the 15% discount they are advertising right now. I haven't seen it yet, I hope the guy knows what he is talking about because that makes it reasonable..
Quick Reply: Cam Installation Question???
