I bought some Gerbing's today
Old 12-25-2008, 09:33 AM
gregbenner's Avatar
gregbenner
gregbenner is offline
Rather than using the Gerbings controller, I mounted a permanent power plug in the left side plastic cover. Also, mounted a Heatroller, both towards the top of the cover, so I can easily reach the Heatroller while riding.
The problem I had with the Gerbings portable controller was that it attached to my belt "under" my jacket. I had to pull over to change settings, not easy sometimes. Plus it was a bit more of a hassle when getting ready.
I use a single controller for all three items (liner or jacket, G3 gloves, and pant liner). I find the realtive temps to fine, so I don't need separate controllers.
Just a thought.
Old 12-25-2008, 11:27 AM
iclick's Avatar
iclick
iclick is offline
I clip mine to the top of my chaps, as if it is cold enough for heated clothing it's cold enough for chaps. I may eventually disassemble the single controller, if it can be done, and mount it to the fairing or elsewhere. I'm balking because I don't like to drill holes or otherwise permanently deface items on a bike.
I've been using only Gerbings Classic gloves with a single controller, but just ordered a HD jacket liner (made by Gerbing). Two of my friends use the liner and gloves on a single controller and find it acceptable, as do some who've reported on this forum--you being one. I also ordered the HD "Y" adapter to merge the glove and liner circuits to the HD liner, which are independent. Is that the way you wired it, or does your liner have only one circuit for liner and gloves?
I found the HD liner to be a bargain ($165) when coupled with Chicago HD's 25%-off-one-item sale going on till Dec. 31st. It has Gerbings Nanowire technology that Gerbing won't incorporate in their own line till next year. It looks like a winner as far as I can tell.
Rampant
08-19-2013 08:44 AM
Jrsess
12-26-2010 07:29 AM
Bluerose
12-04-2007 06:16 AM
sifularson
11-12-2007 02:14 AM
cosmicHD
10-25-2006 09:54 PM
Quick Reply: I bought some Gerbing's today
