Lowering kit
Go to SoLow Motorcycles and give them a call. I've got their lowering kit on my Roadglide and have had for over 3 years with no problems. The ride is much better than the HD Low Profile Shocks. Can't help you on the handlebar question.
http://www.solowmotorcycles.com
Terry.
P.S. We need to do something about your user name. PM me and I can change it for you.
Terry.
I had lowering hardware on my 06 RG and the air shock blew a seal. I'm not sure if it was because of the lowering kit. I replaced the stock air shocks with a set of Progressive 440s Heavy Duty shocks. There was a small sheet with the shocks that warned against using them with lowering hardware. Might be something to that.
try a REACH seat first... lowering the bike will cut down the suspension a bit.. and if you lower one end you'll need to lower the other..... seat will be cheaper, faster, and..... most dealers will allow you to try it on , on YOUR bike...
Check out
www.bitchinbaggers.com
Read the chart and you decide.
I dropped 1 & 1/2"
Lowering kits are not good in my opinion
I dropped 1 & 1/2"
