Question about the FullSac TD conversion kit....
I have the conversion on my bike and the shields look "ok" as long as you don't really stare at them. My buds just noticed how clean the right side of the bike looks now. I ran the conversion this summer with just the Nightrider XIEDs and it ran quite nicely. However towards the end of the year I started to pick up a little preignition and went ahead and installed the A/C and the Pro SERT and had it dynoed. The bike runs even better now. I will ride it and "fine tune" it next summer and if I decide I need more a set of cams are next!
I have suggested to Steve over at FullSac that they market a replacement set of shield, it would clean up the right side very nicely. BTW, FullSac has some of the best customer service out there. Really outstanding folks!
I guess I thought I'd shown you this graphic before, but in any event, note the different "topography" between the airflow mappings for "touring" and "dual" exhausts in http://i33.tinypic.com/1zps6lu.png (made using the two respective base maps included with the last version of the SERT software).
You should clarify that statement a little. If the stock mufflers are the same internally from side-to-side, then you'll be okay converting the system to dual pipes. The '07+ touring bikes have different cans left/right and there's no way I'd use them for duals.
Rush 2" baffles aren't EPA-approved but the sound is hard to beat.
