I went to a local shop and dug through some old heat shields he had laying around and found some that would work and covered my pipes all the way to the slip ones.
I ran a Fullsac kit for a couple of years, using my original set of pipes. Liked the true duals so much I replaced them with Samson pipes and S&S oval mufflers. An expensive way of getting rid of that 'problem'! I actually fitted that heat shield the original way up. I found that certain riding gear got too close to the pipe when that foot was on the ground, because it was in a different location when the other way up.
Well thanks everyone. Their website states that remapping is not needed. I am running the CVO touring muffles with heat shields. I have ordered the Full sac 2" replacement baffles so It will sound very nice. I will try the true duals without the fuel management and then go with a set of XIED's in the near future. Maybe I will use my next income tax check and finish the stage 1 upgrade.
Disagree Glen, I looked into the Fulsac, but found a new set of V&H true duals for $220...with my stock Muffler se tup
I am very saisfied with the set up.
The heat issue is gone..and the sound fits my taste
