Thundermax ???
The great feature is their "Autotune". Load up the T-max with a base map that is close to your set-up and then install and ride. The unit will make adjustments to the map as you ride.
Some people have had great success with the T-max and others said their bikes never ran correctly.
Now with the PC V coming out we will see how Dynojets new unit stacks up to the competition and to its predecessor the PC III.
There is a big difference between the 2 products. The Power Commander is a piggyback module that works in conjuction with your stock ECM, while the Thundermax is actually a replacement ECM that is programmable and with the Auto tune is a complete closed loop system. ( note there is also now a Auto Tune module available for the new Power Commander V as well) In the end, considering with the Thundermax you are getting a complete ECM along with the extensive amount of R&D that goes into reverse engineering the product it is actually a very good value and both products work excellent for their intended applications.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
gant
08-16-2012 11:35 AM
