H4 PIAA XWP A/V Headlight
I know there are alot of posts out there on headlights, but .....
This PIAA Extreme White Plus Anti-Vibration headlight is 60/55W=110/100W. I can't find info saying how much actual power this thing pulls. If it's output is 110/100w wouldn't it pull more than the stock 55/60? What about heat in the housing? Can you modulate it? I'm not sure if I want this or HID. The main reason I'm considering this PIAA is because I can get matching bulbs for the passing lights, color wise. Thoughts? Thanks!
I think 60/55W=110/100W. means:
60 Watts electric power on high beam and 55 W electrical energy on low beam. I think the 110/100 W is the equivalent energy because this thing is very efficient. In other words it is as if yoiu had a 110/110 W bulb but this one consumes 60/55 W.
Now I you want to know the current it consumes here are the calulations:
Power = V*I so I=Power/V then I= 60 W/12 V= 5 A (at high beam which is worst case) and close to stock
