Speedo quit
RE: Speedo quit
My speedo went out in Daytona this year , some one told me to take the sensor out of the casing and clean it but that did not work,, the new sensor is easy to replace it costs about $56. One way to check the sensor is to see if your turn signals turn off automatically because they are tied into your sensor feedback. Let me know how it works out
RE: Speedo quit
I did notice that my cruise didn't work and signal lights did not cancel by themself.
Last week I used a wheel cleaner and tire cleaner. I wonder if any of these products could effect the sensor??
Thanks
Thanks
ORIGINAL: tealdreams
RE: Speedo quit
This is a 1993 Would it have a sensor?
There is a cable going to the left front of the front axle.
There is also a small sensor with a wire attached on the top side of the trans. 5/8" wrench to remove it. The botton/inside of the sensor is spring loaded.
I've removed and cleaned it three times and still no speedo.
I guess the batwing comes off next.
RE: Speedo quit
Where the cable attaches to the front wheel, there should be a nut. If you can disconnect the cable there and give the inner cable a spin with your fingers. You should be able to spin it enough to get a little twitch out of the speedo needle. If not, the inner cable may be broken.
