How Smart are you guys?
Old 12-08-2008, 12:01 AM
gunner11's Avatar
gunner11
gunner11 is offline
I'm pretty smart, "Normal"
Old 12-08-2008, 03:13 AM
Jules's Avatar
Jules
Jules is offline
You're right about 5th being straight cut. First is also straight cut, due to the gear being stronger. There is zero side load with a straight cut gear, which contributes to less wear as well as less chance of breaking, less heat, and less power loss. The other gears are helical cut due to EPA noise testing. The EPA test varies by state, however it's measured by second, third, fourth, or top gear. Since fifth isn't the top gear anymore, it isn't subjected to noise testing.
Old 12-08-2008, 03:51 AM
PeeTuneYa's Avatar
PeeTuneYa
PeeTuneYa is offline
Dumb straight I is a smart tear dan day average bare is I turn the radio up is how much of a smartass is you think I am?
Old 12-08-2008, 05:56 AM
dawg's Avatar
dawg
dawg is offline
Received 3,226 Likes on 1,841 Posts
Originally Posted by RickyB
How smart are you guys?
I'm dumber than a bucket.
Old 12-08-2008, 06:27 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Cosmic Razorback is offline
Received 18,044 Likes on 7,313 Posts
I noticed the whine immediately when we bought our 08 SG. I switched to Gear Savor oil and after the second oil change I do not notice it nearly as much and the CLUNK when you shift gears is not as bad.
Old 12-08-2008, 07:29 AM
SG 1's Avatar
SG 1
SG 1 is offline
I run 75/140 mobile 1 in the tranny, shifts smoother, klunks, and whines less. It also seems to get guieter with more miles.
Old 12-08-2008, 07:32 AM
Birdman143's Avatar
Birdman143
Birdman143 is offline
turn the radio up.
Old 12-08-2008, 07:34 AM
russl179's Avatar
russl179
russl179 is offline
Helps you to remember that you are in 5th....
Old 12-08-2008, 07:54 AM
rochkes's Avatar
rochkes
rochkes is offline
Smile
I gotta agree with Russ on this one. I have an indicator light for 6th gear and I have an indicator whine for 5th gear. I kinda like it...........................
Dennis
Old 12-08-2008, 08:48 PM
bmorebhoy's Avatar
bmorebhoy
bmorebhoy is offline
Originally Posted by Ultra61
How smart are we?...lol
The 5th gear/gearing has straight cut teeth as apposed to all the other gears that have a bevel at the end of each tooth that allows a smoother mesh to the adjoining gears...now if you can tell me why R & D did this at HD I would be much appreciative. However, no worries about the wine we all have it on factory 07's and newer...and I have no problem with it and I like it.
please forgive me if you feel you got this info in error.
From what I understand, 5th gear is straight cut so MoCo can fit all six gears in the gearbox. Bevel cut cogs are thicker than straight cut cogs, a strength issue I guess.
Quick Reply: How Smart are you guys?
