arnott air systems
I put the 13inch air ride on my 09 Ultra so it would go up to the original height. I bought a lowered centerstand and can drop it with zero effort. I then hit the down button an my bike lowers onto the stand. Real cool. The ride is the same as stock with high pressure in the system. You can lower it and ride. I bought the 13 inch ride system so that there would be no chance of hitting my wiring harness under the rear fender with it lowered all the way or if I had a failure. Still lowers and looks slammed when on the jiffy stand. Very pleased with this system. 2 options that I would recommend are the up down switch for the handlebars and the 1.5 inch guage. Hard to tell how much pressure you have in the system without the guage. I forgot to get that and ordered it today. If I have to backup or am on uneven roads at a stop I drop it lower to get better footing. Height is an issue on the 09 UC. This system gets 2 thumbs up from me.
CR,
It should be no problem using a center stand with the air ride. With the right size stand, you would just flip the stand down and then lower the bike onto the stand, It would take zero effort to do this. I will probably be installing this setup in the spring. I believe if you contacted Wheeldock and told them of your setup, they would set you up with a stand for this purpose.
I bought the lowered stand for a unlowered bike. Put the Arnott system on it and raise it to the stock height. I then lower the stand. It makes no or very little contact with the ground. I then lower the air ride system on it (0 effort, perfect for a female rider or a lazy SOB like me).
If you need to back up. Lower your air ride system. You can then stand up with 3-4 inches clearance off the seat and pull your bike back. You will no longer be on your tippy toes. My 09 UC was hard to back up.
Affordable and awsome system. Mine was from Arnott - and no I am not a salesman for them. I researched and found this affordable system. - it works great and I put it on myself and saved all that labor cost.
