Problem Bleeding New Brake Lines!!!
Old 04-09-2006 | 02:08 PM
gliderman's Avatar
gliderman
Default Problem Bleeding New Brake Lines!!!
Put the Goodridge SS Brake lines on my bike over the weekend ( 06' Street Glide). I have used this setup on my last 3 bikes without a problem. All was going good with the install. I bled the system from the calipers up by attaching a big syringe to the bleeder valve. Well, all was well until I noticed I had a bad crush washer at the chrome brake tee under the forks and brake fluid was leaking out pretty bad. So off to the shop for new crush washers. Replaced crush washers on double banjo side of brake tee. Now, I was able to get a lot of air bubbles out of the lines, but I still cannot get it right. I have front brakes, but I can easily pull the brake lever all the way back to the handgrip. When I open the bleeder valves, nothing but fluid comes out, no air bubbles?? If I pump the brake lever I can feel pressure build-up. I would appreciate any help on getting the system right. Thanks........
Old 04-09-2006 | 02:12 PM
Howler's Avatar
Howler
Default RE: Problem Bleeding New Brake Lines!!!
do you have someone pumping them up and holding it down without releaseing the handle until you bleed then close the pit ****? you could have an air pocket up by the handle
Old 04-09-2006 | 02:30 PM
KBES BAGGER's Avatar
KBES BAGGER
ORIGINAL: gliderman
Go to the DIY section there is a good tip on how to take care of this. Pretty much tie your lever back for the night, come morning you are good to go. It worked for me on the King and I **** load of line to bleed.
KB
Old 04-09-2006 | 02:41 PM
gliderman's Avatar
gliderman
KB: thanks for the referral to the DIY section. Only thing I'm not sure about after reading the procedure is if you leave off the master cylinder cover overnight?
Old 04-09-2006 | 03:20 PM
Bryan TTM's Avatar
Bryan TTM
air in the master perhaps
Old 04-12-2006 | 12:20 AM
CHEYENNE's Avatar
CHEYENNE
Mighty Vac...
Old 07-23-2009 | 10:15 PM
JamesJBurrows's Avatar
JamesJBurrows
Stage I
How do I bleed back brake of 2006 Street Glide
Old 07-24-2009 | 04:56 AM
galtjunk's Avatar
galtjunk
Install the bleeders with the one way valve built into them. They make one man bleeding a breeze.
Old 07-24-2009 | 07:51 AM
hdfat2001's Avatar
hdfat2001
Backs are easy. Either Mity Vac, or just press the lever down, open the bleeder to a hose in a comtainer with a little fluid in it. close bleeder and repeat.
On the fronts +1 on tying the lever down over night. I use a tie wrap and just let it sit the pressure brings the remaining bubbles up to the MC. If that doesn;t work keep looking for any loose connections at the T or the banjos.
zgunnar48
04-30-2015 08:08 PM
smittyp83
05-13-2014 05:09 PM
eric2011Deluxe
04-01-2012 03:15 AM
logan hd
14
07-20-2010 12:06 PM
braggster
05-20-2007 11:51 AM
