Custom Passing Lamp Bracket Turn Signal Kit
Old 04-08-2006 | 07:24 PM
Candy Red Road Glide's Avatar
Default Custom Passing Lamp Bracket Turn Signal Kit
Has anyone installed this? The reason i ask is i opened the box the turn signals were in and no instructions no bolts. Do i need additional bolts or are they in the bag of bolts that came with the lamp brackets? Also is this a pretty simple install or a dealer install? Thanks for any and all replies.
Old 04-08-2006 | 07:50 PM
Bruce00's Avatar
Bruce00
Default RE: Custom Passing Lamp Bracket Turn Signal Kit
I would think it should be a straight forward bolt up. Can you post some pics of the setup you bought? Is it an HD part or aftermarket?
Old 04-08-2006 | 08:22 PM
Here is the passing lights with the turn signals mounted http://www.harley-davidson.com/gma/g...bmLocale=en_US
It is the same thing as what was used on the 05 SE EG
Turn signals are part #69228-04
Old 04-08-2006 | 10:08 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Kit 69227-04A has all the hardware that you need....
Old 04-08-2006 | 11:02 PM
harley0711's Avatar
harley0711
those were first used on SE models... I have a set on my FLHTCI... If I remember right,,, you have to do some cutting and splicing,,, I will check and see if my inst are still around... its really no big deal,,,
Old 04-08-2006 | 11:18 PM
Bruce00's Avatar
Bruce00
ORIGINAL: 05_eglideclassic
Those are a nice setup. My buddy has them on his Road King and they look sweet, alot cleaner than my setup. But I just bought LED replacement bulbs for the big turn signals.
I believe we are riding sunday and I'll ask him what the installation required
Old 04-08-2006 | 11:33 PM
HD Renegade's Avatar
HD Renegade
Not sure of how much help this would be as I did not install mine. I did give the dealer the wiring diagram that I found in the DIY section on how to wire them up so that they work when the high beam switch is on. Per the HD wiring, they are normally wired so that they shut off when the high beam switch is on.
Bob
Old 04-09-2006 | 11:46 AM
Thanks for all the info
Old 04-09-2006 | 01:26 PM
BladeMan's Avatar
BladeMan
I put them on my SG. They are fairly easy to install. I also installed them so that they would stay on with my high beams.
Old 04-09-2006 | 08:36 PM
get_off_it's Avatar
get_off_it
Installed em on my '06 SG. Got access to a fax machine? If you do PM me with a fax number and I'll fax instructions to you.
