Why not change the mirrors?
Old 11-28-2008, 06:38 PM
racklefratz's Avatar
racklefratz
racklefratz is offline
Originally Posted by HDQuest
Raclefratz, LED lights look real sharp. Are the LED mirros and the windshield LED, HD products ?
Yep, Harley parts - 92059-07 and 57335-08.
Old 11-28-2008, 07:04 PM
jjohnson77536's Avatar
jjohnson77536
jjohnson77536 is offline
are the led on all the time? and brighter when flashing?
Old 11-28-2008, 07:19 PM
racklefratz
No, they only have one intensity level.
If a turn signal is not active, they stay on continuously like the turn signals.
When a turn signal is activated, the mirror LEDs on that side and the end LED on the windshield strip on that side both flash on and off. They don't get brighter. As long as that turn signal is still active, the rest of the windshield LEDs stay on steady, along with the LEDs on the other mirror and the stock turn signal on the other side.
Old 11-28-2008, 08:03 PM
will2002's Avatar
will2002
will2002 is offline
Received 2,120 Likes on 1,027 Posts
I have owned 7 Harleys. Changed the mirrors on each one of them. Some more than once!
Old 11-28-2008, 08:05 PM
TheBagger's Avatar
TheBagger
TheBagger is offline
I like the classic teardrops on my RK.
Old 11-28-2008, 08:16 PM
Yachtman's Avatar
Yachtman
Yachtman is offline
Masterblaster,
You hit the nail on the head. In S. Fl you have to have the Split Visions!!
Old 11-28-2008, 09:17 PM
tima's Avatar
tima
tima is offline
I really like the idea of the split vision. Going to have to check those out. Full face helmet in the winter, it's hard to turn all the way around to see.
Old 11-28-2008, 09:24 PM
tmblweed's Avatar
tmblweed
tmblweed is offline
I decided on a new set today, probably pick up a set in Dec.
Old 11-28-2008, 09:30 PM
tjohnston9's Avatar
tjohnston9
tjohnston9 is offline
I think mirrors are a good way to emphasize a theme with your ride - skulls, flames, etc. Just don't get 'em too small. I tried some sharp flame mirrors, but couldn's see anything behind me cuz they were too small...
Old 11-28-2008, 09:45 PM
Whiskers's Avatar
Whiskers
Whiskers is offline
Originally Posted by jack49
If those are the Tailfin mirrors,I've tried em and they were terrible. The mirror base
comes in contact with master cylinder,when you try turning for adjustment. Will
need an extention to raise the the base or mount the mirror in the clutch lever pin
position.
Yep, those are the tailfin mirrors. I have them on my RKC...they look damn fine, but you will need an adaptor to make them fit. Also, if you get a certain adaptor, the threaded stem is too short so you'll have to replace it with some new all-thread. Its a pain, but they do look great once they're on the bike.
Ride safe.
Quick Reply: Why not change the mirrors?
