Wheels Stained on 09 Ultra - How to clean?
Water contains oxygen, at a higher concentration than air. It will oxidize the aluminum at a higher rate than the surounding air. Result is what looks like a stain. Bare aluminum should always be dryed as soon as posible and for long term storage, like winter a wipe with wd40 on a rag will leave a protective grease film on it to protect it. Wax won't work on aluminum cause it has no pores for it to embed into. Once these spots show up, the surface material needs to be taken down to virgin aluminum again. If it's only minor 1500-2000 grit sandpaper and then blend the whole wheel in with that. Follow up with the polishing method of choice on the whole wheel. Bare aluminum is a pain, but with elbow grease and patience it can always, if not neglected too long be brought back to new looking condition, and sometimes better. If it's a machined looking finish, instead of polishing use a green scotchbrite pad. Ask the ole for one as it's a common item at the sink.
Ron
Ron
I really can't tell from the picture but it looks like what happens when you leave S100 Wheel Cleaner on too long. I would bet that is what happened at the Dealer when they washed it before you picked it up and the dummy that washed it left it on too long. I would go right back to the Dealer and show him!.
Had the same issue, think its brake dust staining them, could not get the stain off but didnt really care as I was going to chrome them and did. I also switched to lyndall pads, almost no dust comes off them.
http://www.chromeprosplating.com/
Here are pics of the results
https://www.hdforums.com/forum/touring-models/292938-09-stock-rims-chrome-pros-pics.html
Take it back to the dealer! Sounds like the aluminum is oxidizing under the clearcoat or the clearcote has been pitted with something it didn't like. If soap and water won't take care of it - they'll probably need replacing. Better do it now - or live with it from now on!
No aluminum polish will help because it has a layer of clear paint on it, and you definately don't want to go down the polishing aluminum wheels path - a lot of work!
Also, is the stain only on one side? Perhaps you have something leaking, although I'm not sure any oil or fluid used in the drivetrain would stain like that. Is there evidence of any oil on surrounding parts? You could also have run over some chemical on the road that had spilled out of another vehicle.
