power Commander
There are lots of fuel management systems out there. Basically I see three types. Type one you put it on using the map installed and there are no real adjustments. The FuelPak is such a unit. Type two can have the map changed by yourself using a simple program supplied with the unit through a PC. The Power Commander III is an example. Type three is a unit which when installed looks at how you ride and makes adjustments itself. Thunder Max is an example. Which type would you like to have installed on your bike. How much do you want to spend?
course the 4th type is the SERT or HD Pro tuner, which allows you to install a map or build/adjust a map in the existing ECU on the bike.
Dealer?? You can do it yourself, certainly don't need the dealer to do it. course the SERTs are HD, so that is where you will have to likely go to buy one.
patsfanatic
03-02-2013 03:43 PM
anubisss
03-08-2007 10:48 PM
