Street Glide rear fender light
You're welcome. Wish there was a "sticky" on this since it's a popular modification on Touring models. For example, your RG has the TP wiring harness on the bike that is used for TP lights. But the SG LED uses that connector for the LED. So, if you have or want to add a TP with lights, the wiring has to be changed slightly. Either a pigtail for the TP harness, or a different connector for the SG LED to plug into the tail light circuit board behind the tail light lens.
If you don't have a lighted TP or plan to add one, you can simply mount the facia (drill the fender or use the double-sided tape), install the LED and connect it to the TP harness.
There's at least one ebay seller offering kits; if you buy from HD, especially a 20% off list dealer (e.g. Zanotti's) you'll do much better cost-wise.
Good luck with our project. PM the RG guys who've done the mod
Where are you getting your information? I ask because I've done this mod and read here of others who have also. A painted SG facia is $99 list, primered is $56; and, the LED light with harness is $65 IIRC. The links in my earlier post provide part numbers to verify.
sprint12
01-19-2011 10:25 PM
tsglide
05-29-2007 11:23 PM
